[gdal-dev] Segfault in GDALWriteBlock
Kurt Schwehr
schwehr at gmail.com
Thu May 5 06:56:27 PDT 2016
What version of GDAL are you using? Can you provide the command or calling
code that you are using? Can you use a debugger and give a stack trace?
On Thu, May 5, 2016 at 12:42 AM, jramm <jamessramm at gmail.com> wrote:
> Hi I am getting a segfault in a call to GDALWriteBlock with this code:
> Stepping through seems to suggest that the segfault is arising from line
> 171
> of "geo_new.c" in libgeotiff:
> I cant find previsely what it is I have done wrong to cause this in my
> code....any ideas?
> http://osgeo-org.1560.x6.nabble.com/Segfault-in-GDALWriteBlock-tp5264660.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160505/e3c11bc2/attachment-0001.html>
