[gdal-dev] Starting a discussion on style and coding guidelines
Damian Dixon
damian.dixon at gmail.com
Thu May 5 08:41:13 PDT 2016
I'm currently stuck on the following compilers:
- Visual Studio 2010 SP1
- GCC 4.7
C++11 is only partially supported with these compilers.
Regards
Damian
On 4 May 2016 at 23:51, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 4 May 2016 at 23:30, Kurt Schwehr <schwehr at gmail.com> wrote:
>> To start off the conversation, I wrote up a doc on changing large C
>> arrays on the stack to std::vectors to get this data off of the stack and
>> to simplify initialization.
> Since many, if not most, of the ideas rely on availability of the C++11
> features,
> it might be a good idea to first agree on C++11 as the lowest
> required C++ compilation mode.
> Let's poll if there are any users who require C++03 at all.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160505/e0b669bb/attachment.html>
