[gdal-dev] Starting a discussion on style and coding guidelines
Andrew Bell
andrew.bell.ia at gmail.com
Mon May 9 13:37:20 PDT 2016
On Mon, May 9, 2016 at 2:49 PM, Mateusz Loskot <mateusz at loskot.net> wrote:
> Point taken.
> Although the proposal looks OK, I'd suggest to check what
> assembler code generates your favourite C++ toolkit,
> or at least measured times for
> int anVals[256];
> memset(anVals, 0, 256*sizeof(int));
Are "we" doing memset anymore in these cases?
int anVals[256] = {};
seems preferable
> vs
> std::vector<int> oVals(256, 0);
> and compare with:
> std::vector<char> oVals(256, 0);
Think vector is a bad solution for something that's fixed. Just write
something. But I already suggested that and wrote something... :)
Do you know why they are wedded to a 16K stack?
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160509/0f63dfc9/attachment.html>
