[gdal-dev] ogr geojson columns that start with null converted to string
Even Rouault even.rouault at spatialys.com
Wed May 18 06:28:03 PDT 2016
Le mercredi 18 mai 2016 14:06:08, Raluca a écrit :
> Hi,
> At the moment the geojson reader automatically converts an attribute where
> the first feature is null to string. Is it possible to check values also
> from the next features and based on that to set the type of the column?
I've just fixed it per https://trac.osgeo.org/gdal/ticket/6517
Best regards,
Even
http://www.spatialys.com
