[gdal-dev] GeoPDF
Frank Broniewski
frank.broniewski at gmail.com
Wed May 18 09:26:00 PDT 2016
Hi Even,
Am 18.05.2016 um 17:10 schrieb Even Rouault:
> Sure. There are 2 specifications mentionned in http://gdal.org/frmt_pdf.html :
> - Adobe Supplement to ISO 32000:
> http://www.adobe.com/devnet/acrobat/pdfs/adobe_supplement_iso32000.pdf
> - OGC GeoPDF Encoding Best Practice Version 2.2 (08-139r3) :
> http://portal.opengeospatial.org/files/?artifact_id=40537
> But I doubt you'll enjoy their reading (especially the ISO 32000 one). In
> practice the support has been developed by dumping existing files.
Yeah, I've looked at them before and thought of something more easily
readable - but I will give them a second look anyway.
> The GDAL PDF driver supports update of an existing PDF to add
> georeferencing to it. You can do that for example with the -a_ullr and
> -a_srs flags of the gdal_edit.py script. You can also look at the
> pdf_update_gt() test in
> https://svn.osgeo.org/gdal/trunk/autotest/gdrivers/pdf.py This is also
> documented in the "Update of existing files" section of
Cool, thanks for the links!
Frank
