[gdal-dev] GeoPDF
Frank Broniewski frank.broniewski at gmail.com
Wed May 18 09:30:42 PDT 2016
Hi Luca,
> I developed a plugin for QGIS to export layers (vector and raster) to
> geospatial PDF using GDAL library.
> I'm waiting the authorization from the customer to publish it in the
> plugin repository.
this sounds interesting. But your plugin cannot save a map composition
with legend, neatline and all the other "carto things", can it? That's
what I am after in the end. But if you have some docs or other info to
share, I will gladly accept any help ;-)
Frank
