[gdal-dev] Get a List of tiles source name from the gpkg_content
Jukka Rahkonen
jukka.rahkonen at maanmittauslaitos.fi
Thu May 19 10:20:54 PDT 2016
Gane R <gane.prog <at> gmail.com> writes:
> I see the usage of the gdalinfo for the gpkg with multiple tile source as
Subdataset,
> I also saw the source code of gdalinfo getting the subdataset
> Q1: Can I get a list of tiles source name (table_name) in gpkg_contents
data_type as tiles?
I am not sure if I understood what you mean, but GeoPackage is a database
and you can use SQL and ogrinfo for doing anything that is possible with SQL.
ogrinfo test.gpkg -sql "select table_name, data_type from gpkg_contents
where data_type='tiles'"
INFO: Open of `test.gpkg'
using driver `GPKG' successful.
Layer name: SELECT
Geometry: None
Feature Count: 2
Layer SRS WKT:
(unknown)
table_name: String (0.0)
data_type: String (0.0)
OGRFeature(SELECT):0
table_name (String) = one
data_type (String) = tiles
OGRFeature(SELECT):1
table_name (String) = two
-Jukka Rahkonen-
