[gdal-dev] CommitTicketUpdater Trac plugin
Even Rouault
even.rouault at spatialys.com
Thu May 19 12:52:08 PDT 2016
just to notify you that since the upgrade to Trac 1.0.5 a few months ago, the
CommitTicketUpdater plugin is enabled, which enables to automatically adds
comments in tickets from SVN commit messages.
See https://trac.osgeo.org/gdal/ticket/6519 as an example.
Here's the doc of the CommitTicketUpdater plugin :
This component hooks into changeset notifications and searches commit messages
for text in the form of:
command #1
command #1, #2
command #1 & #2
command #1 and #2
Instead of the short-hand syntax "#1", "ticket:1" can be used as well, e.g.:
command ticket:1
command ticket:1, ticket:2
command ticket:1 & ticket:2
command ticket:1 and ticket:2
In addition, the ':' character can be omitted and issue or bug can be used
instead of ticket.
You can have more than one command in a message. The following commands are
supported. There is more than one spelling for each command, to make this as
user-friendly as possible.
close, closed, closes, fix, fixed, fixes
The specified tickets are closed, and the commit message is added to them
as a comment.
references, refs, addresses, re, see
The specified tickets are left in their current status, and the commit
message is added to them as a comment.
A fairly complicated example of what you can do is with a commit message of:
Changed blah and foo to do this or that. Fixes #10 and #12, and refs #12.
This will close #10 and #12, and add a note to #12.
Credit to strk for mentionning this capability
Even
http://www.spatialys.com
