[gdal-dev] GDAL python bindings build error (gcc command replaced	by bash)
    James Nunn
    jamesnunn123 at gmail.com
    Wed May 25 08:13:50 PDT 2016
Hi
I'm building gdal on linux (64bit ubuntu 16) with python bindings, and I'm
coming across a strange error right at the end of the python build steps
where exactly 4 commands which *should* be run with `x86_64-linux-gnu-gcc`
are instead run as `/bin/bash`.
Here are the last few lines of output before the error is encountered (look
for /bin/bash -pthread ... command after the python header warnings:
make[1]: Entering directory '/home/james/src/gdal/gdal/swig'
for dir in python ; do (cd $dir; make build) || exit; done
make[2]: Entering directory '/home/james/src/gdal/gdal/swig/python'
rm -f setup_vars.ini
echo 'GNM_ENABLED=no' >> setup_vars.ini
python setup.py build
running build
running build_py
creating build
creating build/lib.linux-x86_64-2.7
copying gdal.py -> build/lib.linux-x86_64-2.7
copying ogr.py -> build/lib.linux-x86_64-2.7
copying osr.py -> build/lib.linux-x86_64-2.7
copying gdalconst.py -> build/lib.linux-x86_64-2.7
copying gdalnumeric.py -> build/lib.linux-x86_64-2.7
creating build/lib.linux-x86_64-2.7/osgeo
copying osgeo/gnm.py -> build/lib.linux-x86_64-2.7/osgeo
copying osgeo/gdalnumeric.py -> build/lib.linux-x86_64-2.7/osgeo
copying osgeo/gdal_array.py -> build/lib.linux-x86_64-2.7/osgeo
copying osgeo/gdalconst.py -> build/lib.linux-x86_64-2.7/osgeo
copying osgeo/osr.py -> build/lib.linux-x86_64-2.7/osgeo
copying osgeo/__init__.py -> build/lib.linux-x86_64-2.7/osgeo
copying osgeo/gdal.py -> build/lib.linux-x86_64-2.7/osgeo
copying osgeo/ogr.py -> build/lib.linux-x86_64-2.7/osgeo
running build_ext
building 'osgeo._gdal' extension
creating build/temp.linux-x86_64-2.7
creating build/temp.linux-x86_64-2.7/extensions
x86_64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall
-Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g
-fstack-protector -Wformat -Werror=format-security -fPIC -I../../port
-I../../gcore -I../../alg -I../../ogr/ -I../../ogr/ogrsf_frmts -I../../gnm
-I../../apps -I/usr/include/python2.7
-I/home/james/local/farmenv/local/lib/python2.7/site-packages/numpy/core/include
-I/home/james/src/gdal/gdal/include -c extensions/gdal_wrap.cpp -o
build/temp.linux-x86_64-2.7/extensions/gdal_wrap.o
cc1plus: warning: command line option ‘-Wstrict-prototypes’ is valid for
C/ObjC but not for C++
In file included from /usr/include/python2.7/Python.h:133:0,
                 from extensions/gdal_wrap.cpp:155:
extensions/gdal_wrap.cpp: In function ‘PyObject*
_wrap_MajorObject_SetMetadata__SWIG_0(PyObject*, PyObject*)’:
/usr/include/python2.7/abstract.h:1354:62: warning: deprecated conversion
from string constant to ‘char*’ [-Wwrite-strings]
 #define PyMapping_Items(O) PyObject_CallMethod(O,"items",NULL)
extensions/gdal_wrap.cpp:9115:31: note: in expansion of macro
‘PyMapping_Items’
         PyObject *item_list = PyMapping_Items( obj1 );
/bin/bash -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions
-Wl,-Bsymbolic-functions -Wl,-z,relro -fno-strict-aliasing -DNDEBUG -g
-fwrapv -O2 -Wall -Wstrict-prototypes -Wdate-time -D_FORTIFY_SOURCE=2 -g
-fstack-protector -Wformat -Werror=format-security -Wl,-Bsymbolic-functions
-Wl,-z,relro -Wdate-time -D_FORTIFY_SOURCE=2 -g -fstack-protector -Wformat
-Werror=format-security build/temp.linux-x86_64-2.7/extensions/gdal_wrap.o
-L../../.libs -L../../ -L/home/james/src/gdal/gdal/lib -lgdal -o
build/lib.linux-x86_64-2.7/osgeo/_gdal.so
/bin/bash: -d: invalid option
error: command '/bin/bash' failed with exit status 1
GNUmakefile:74: recipe for target 'build' failed
make[2]: *** [build] Error 1
make[2]: Leaving directory '/home/james/src/gdal/gdal/swig/python'
GNUmakefile:30: recipe for target 'build' failed
make[1]: *** [build] Error 2
make[1]: Leaving directory '/home/james/src/gdal/gdal/swig'
GNUmakefile:104: recipe for target 'swig-modules' failed
make: *** [swig-modules] Error 2
If I manually re-run the failing commands replacing `/bin/bash` with
`x86_64-linux-gnu-gcc`, the entire build eventually succeeds.
Can anyone shed light on why the command is being replaced?
Regards
James
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160525/a8ca43db/attachment-0001.html>
