[gdal-dev] GDAL WMTS Driver - How do you control the Tile Matrix Set's Tile Level?
esacree
esacree at knology.net
Sun Nov 6 18:27:26 PST 2016
I am trying to use the new GDAL_WMTS driver with GDAL Version 2.1.
Problem: The thread that receives the data from the server gets a GDAL data
set handle with a total data buffer size of 4,294,967,296 for a 4 band
image.
Questions:
1. Does GDAL_WMTS driver return all tiles combined into a single image
memory buffer?
2. Is the data buffer returned for WMTS retrieved the same way as for WMS
with a call to the GDAL Data Set rasterio function?
3. Is there any way to control which tile level in the TileMatrixSet is
returned for GDAL_WMTS? A TileLevel tag is in the GDAL_WMS XML definition
http://www.gdal.org/frmt_wms.html but not in the GDAL_WMTS
definition/example http://www.gdal.org/frmt_wmts.html
According to the returned data parameters, the image is huge 32K x 32K x 4
with around 4GB of memory needed to create a 4 band image. The area
requested is a fairly small area around the Cumberland River.
Here’s a sample of the Service Request sent to the WMTS server. The XML is
similar to the request generated by GDAL_Translate for the server. The
DataWindow coordinates are much smaller and in range of the server’s data.
Request coordinates were converted from EPSG:26926 to EPSG:3857 for the
request shown below.
<GDAL_WMTS>
<GetCapabilitiesUrl>http://basemap.nationalmap.gov/arcgis/rest/services/USGSShadedReliefOnly/MapServer/WMTS/1.0.0/WMTSCapabilities.xml</GetCapabilitiesUrl>
<Layer>USGSShadedReliefOnly</Layer>
<TileMatrixSet>default028mm</TileMatrixSet>
<DataWindow>
<UpperLeftX>-9664344.849763</UpperLeftX>
<UpperLeftY>4328551.472775</UpperLeftY>
<LowerRightX>-9646502.672226</LowerRightX>
<LowerRightY>4318753.685277</LowerRightY>
</DataWindow>
<BandsCount>4</BandsCount>
<Cache />
<UnsafeSSL>true</UnsafeSSL>
<ZeroBlockHttpCodes>204,404</ZeroBlockHttpCodes>
<ZeroBlockOnServerException>true</ZeroBlockOnServerException>
</GDAL_WMTS>
With the exception of the DataWindow parameters, the request matches the
test request generated by GDAL_Translate for the server. The DataWindow
values are well within the full range of the WMTS Server for the requested
layer.
Thanks in advance!
Elaine
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-WMTS-Driver-How-do-you-control-the-Tile-Matrix-Set-s-Tile-Level-tp5294530.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
