[gdal-dev] GDAL WMTS Driver - How do you control the Tile Matrix Set's Tile Level?
Even Rouault
even.rouault at spatialys.com
Mon Nov 7 13:29:10 PST 2016
Le lundi 07 novembre 2016 22:07:09, esacree a écrit :
> Code Snippet:
> GDAL_WMTS XML file – area around Cumberland River:
> Code is trying to get raster tiles from the server not capabilities. Using
> the example for the Local Service Description File here:
> http://www.gdal.org/frmt_wmts.html .
> 1. Here is the WMTS XML file generated to request tiles for the area.
> Note there is no image size limit specified in the request below. A WMS
> request is limited by size in the XML file.
> <GDAL_WMTS>
> <GetCapabilitiesUrl>http://basemap.nationalmap.gov/arcgis/rest/services/USG
> SShadedReliefOnly/MapServer/WMTS/1.0.0/WMTSCapabilities.xml</GetCapabilitie
> sUrl> <Layer>USGSShadedReliefOnly</Layer>
> <TileMatrixSet>default028mm</TileMatrixSet>
> <DataWindow>
> <UpperLeftX>-9664344.849763</UpperLeftX>
> <UpperLeftY>4328551.472775</UpperLeftY>
> <LowerRightX>-9646502.672226</LowerRightX>
> <LowerRightY>4318753.685277</LowerRightY>
> </DataWindow>
> <BandsCount>4</BandsCount>
> <Cache />
> <UnsafeSSL>true</UnsafeSSL>
> <ZeroBlockHttpCodes>204,404</ZeroBlockHttpCodes>
> <ZeroBlockOnServerException>true</ZeroBlockOnServerException>
> </GDAL_WMTS>
> 2. Call to GDAL Open with the above XML file name to create the data set
> using the XML Service Request file:
> GDALDataset* pdataset = (GDALDataset*)GDALOpen(xmlPath.c_str(),
> GA_ReadOnly);
> if (!pdataset)
> OutputDebugStringA("GDALOpen failure");
> OutputDebugStringA(CPLGetLastErrorMsg());
> return false;
> // Note: For the WMTS request above, the full raster image size of about
> 56K x 39K is coming back GetRasterXSize and GetRasterYSize. For the older
> GDAL_WMS the image sizes are the request size specified in the WMS XML
> Service Request File. There is no limit on the image size in the WMTS Tile
> server request.
> Here is the data setup in the info struct. The info data is used later by
> the call back function that gets the raster data:
> info->m_width = pdataset->GetRasterXSize(); // Returning full size
> image pixel width
> info->m_height = pdataset->GetRasterYSize(); // Returning full size
> image pixel height
> info->m_dtype = GDTByte;
> info->m_dbands = 4;
> nPixelSpace = 4; // 4 Bytes per pixel for RGBA
> nLineSpace = m_width * nPixelSpace;
> nBandSpace = 1;
> int bandMap[] = { 1,2,3,4 };
> 3. Data Receipt: Later Data coming into the GDAL thread call back
> function:
> err = pdataset->RasterIO( GF_Read, 0, 0, info->m_width, info->m_height,
> (void*)tmpbuff, info->m_width, info->m_height,
> info->m_dtype, info->m_dbands, bandMap,
> nPixelSpace, nLineSpace, nBandSpace);
OK so you are requesting a 56K x 39K image in a single request. If that's
too big (which is likely), then ask for smaller buffer dimensions like
(void*)tmpbuff, info->m_width / 16, info->m_height / 16,
> Elaine
> http://osgeo-org.1560.x6.nabble.com/GDAL-WMTS-Driver-How-do-you-control-th
> e-Tile-Matrix-Set-s-Tile-Level-tp5294530p5294705.html Sent from the GDAL -
> Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
