[gdal-dev] GDAL 2.1.2 compilation error
Even Rouault even.rouault at spatialys.com
Wed Nov 9 12:14:31 PST 2016
Craig,
I've downloaded a Fedora 15 x86_64 DVD iso (setup with Development
environment) and just tried on GDAL 2.1.2
 ./configure \
          --disable-shared \
          --enable-static \
          --with-pic \
          --without-ld-shared \
          --without-libtool
and it builds fine. Both with gcc 4.6.0 that comes with the DVD, and 4.6.3
after the updates.
So it would seem that it is one of the dependency that might cause the issue
(which seems odd)
Even
http://www.spatialys.com
