[gdal-dev] How to replace an osm key?
Djordje Spasic
issworld2000 at yahoo.com
Fri Nov 11 05:50:34 PST 2016
Hi Jukka,
Thank you for the quick and informative reply!
But I am not sure I understood you.
So first I need to convert the .osm file to .shp files with ogr2ogr.exe
And then I am calling the ogrinfo.exe on specific .shp file (multipolygons.dbf ?)
ogr2ogr.exe --config OSM_USE_CUSTOM_INDEXING NO -skipfailures -f "ESRI Shapefile" output.shp input.osm
ogrinfo.exe -dialect sqlite -sql "select geometry, building as bldg
from output.shp/multipolygons.dbf" input.osm.pbf
On Friday, November 11, 2016 2:36 PM, jratike80 <jukka.rahkonen at maanmittauslaitos.fi> wrote:
You can rename the fields with SQL
ogrinfo -dialect sqlite -sql "select geometry, building as bldg
from multipolygons" hamburg-latest.osm.pbf
Geometry Column = GEOMETRY
bldg: String (0.0)
Slight drawback is that you must include all the attributes in SELECT but
you can save the command into text file for reuse.
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-How-to-replace-an-osm-key-tp5295339p5295342.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161111/09eb27a5/attachment.html>
