[gdal-dev] Converting MULTILINESTRING to LINESTRING
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Fri Nov 18 00:01:09 PST 2016
Nelson A. de Oliveira wrote
> Hi!
> Sorry if it's not the appropriated place to ask this, but is there a
> way to convert MULTILINESTRING to LINESTRING?
> For example:
> ogr2ogr -f "SQLite" -gt 65536 -dsco SPATIALITE=YES database.sqlite
> shape.shp
> ERROR 1: Cannot insert feature with geometry of type MULTILINESTRING
> in column GEOMETRY. Type LINESTRING expected
> ERROR 1: Unable to write feature 178 from layer merged.
> ERROR 1: Terminating translation prematurely after failed
> translation of layer merged (use -skipfailures to skip errors)
> I don't want to skip the features, but convert them.
> I could open the shapefile in QGIS and use "Multipart to Singleparts",
> but it will be a non-automatic and non-cli step.
> Is there a way to do this with ogr2ogr (or other related tool), please?
> Thank you!
> Best regards,
> Nelson
If you want to write all that you have in the shapefile into Spatialite, use
ogr2ogr with switch -nlt PROMOTE_TO_MULTI. Obviously your shapefile contains
a mixture of linestrings and multilinestrings. However, if you want to
explode multilinestrings into linestrings use switch -explodecollections.
Both are documented in http://www.gdal.org/ogr2ogr.html.
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Converting-MULTILINESTRING-to-LINESTRING-tp5296370p5296402.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
