[gdal-dev] Changing layer name of GeoJSON datasets
Even Rouault even.rouault at spatialys.com
Sat Nov 19 07:24:52 PST 2016
Hi
Currently the GeoJSON datasource always return "OGRGeoJSON" as a layer name,
which is quite boring (if you convert the geojson into a multi-layer capable
dataousrce, you always have to rename the layer to something more meaningful)
I'd consider changing that to take the basename of the datasource, ie "my" if
the filename is "/path/to/my.geojson". This would be similar to many other
drivers like Shapefile, CSV, MapInfo File, JML ... (ie drivers with a single
layer per file)
For URLS coming from HTTP services with query parameters "?foo=bar&...", we
would likely keep the "OGRGeoJSON" name.
I'd also consider adding and reading a "name" extension member in the
FeatureCollection object to store/retrieve the layer name. This would have the
priority over the filename based rule when it exists.
	"type": "FeatureCollection",
	"name": "layer_name",
	"features": [
Thoughts ?
Even
http://www.spatialys.com
