[gdal-dev] CAD (DWG) Driver
Dmitry Baryshnikov
bishop.dev at gmail.com
Sat Nov 19 08:34:02 PST 2016
Hi Even,
The big_endian test now is ok. But osx crash at the exiting of python
after all test finished successfully.
This is error message:
libc++abi.dylib: terminating with uncaught exception of type std::__1::system_error: mutex lock failed: Invalid argument
./gdal/ci/travis/osx/script.sh: line 13: 56363 Abort trap: 6 python run_all.py
I find out that this may be the result of resources free order:
https://github.com/dmlc/mxnet/issues/309
https://github.com/google/benchmark/issues/52
No idea why this occurred then C++11 used. I'll try to use osx CI test disabling the CAD driver to exclude this possible issue.
Best regards,
Dmitry
19.11.16 17:18, Even Rouault пишет:
> On samedi 19 novembre 2016 16:52:09 CET Dmitry Baryshnikov wrote:
>> Hi,
>> I fixed all reported by Even and Kurt errors and recommendations in CAD
>> (DWG) driver and most of recommendations in OpenCAD library. The pull
>> request (https://github.com/OSGeo/gdal/pull/164) passed all the checks
>> successful. It seems to me the driver is ready to merge to the trunk.
>> This will simplify testing and reviewing the new driver by community.
>> There are some problems in big_endian and xcode CI tests, because of
>> C++11 compiler flags (not a problem of CAD driver code, etc.) - I
>> disable C++11 (and appropriate the CAD driver too) in this tests. It
>> seems to me that not blocking issue and I can merge the code to trunk.
>> Are there any objections?
> Massive +1
> I've just noticed your comment https://github.com/OSGeo/gdal/pull/
> 164#issuecomment-261525037 about the issue with C++11 in the GeoTIFF driver.
> I've just fixed that code, so you can now likely re-enable C++11 in the
> big_endian and mac envs
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161119/8a1b3041/attachment-0001.html>
