[gdal-dev] CAD (DWG) Driver
Kurt Schwehr
schwehr at gmail.com
Sat Nov 19 10:06:26 PST 2016
I'm really not sure.
You can certainly try removing that C++11 mutex. It was added based on the
comment at that point in the code. We'll just have to keep an eye out for
possible occasional flakes. If that's the case, we'll need to carefully
work through the logic and try to figure out a solution that works for
everything.
+1 for getting the driver into the tree. It will be easier to make
additional changes to either it or GDAL with it in the same tree.
On Sat, Nov 19, 2016 at 8:49 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On samedi 19 novembre 2016 19:34:02 CET Dmitry Baryshnikov wrote:
> > Hi Even,
> > The big_endian test now is ok. But osx crash at the exiting of python
> > after all test finished successfully.
> > This is error message:
> > libc++abi.dylib: terminating with uncaught exception of type
> > std::__1::system_error: mutex lock failed: Invalid argument
> > ./gdal/ci/travis/osx/script.sh: line 13: 56363 Abort trap: 6
> > python run_all.py
> > I find out that this may be the result of resources free order:
> > https://github.com/dmlc/mxnet/issues/309
> > https://github.com/google/benchmark/issues/52
> > No idea why this occurred then C++11 used. I'll try to use osx CI test
> > disabling the CAD driver to exclude this possible issue.
> Hum, I think this might be indeed an issue with resource free order between
> the GDALDestroy() destructor function (in gcore/gdaldllmain.cpp) and the
> static C++11 mutex Kurt introduced in
> https://github.com/OSGeo/gdal/commit/a9b947d6850d496f09e668f4cd1488
> 26d45d9fa9
> If this mutex gets destroyed before GDALDestroy() is called, then things
> might
> indeed crash.
> I think we should remove this static C++11 mutex. Kurt ?
> (Another option would be to remove the library destructor function. I've
> the
> feeling they cause more harm than good.)
> Spatialys - Geospatial professional services
> http://www.spatialys.com
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161119/da36d65e/attachment.html>
