[gdal-dev] Troubleshooting palette management. Potential bug in palette for overviews?
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Fri Nov 25 03:14:52 PST 2016
JAI-ImageIO TIFFDecompressor does the same (Line 0888):
https://java.net/projects/jai-imageio-core/sources/svn/content/trunk/src/share/classes/com/sun/media/imageio/plugins/tiff/TIFFDecompressor.java?rev=254
(also putting an imageio-ext link for quicker reference)
https://github.com/geosolutions-it/imageio-ext/blob/master/plugin/tiff/src/main/java/it/geosolutions/imageio/plugins/tiff/TIFFDecompressor.java#L900
Note the:
redLut[i] = (byte)((colorMap[i]*255)/65535);
which results into using a 257 scale factor.
Cheers,
Daniele
On Fri, Nov 25, 2016 at 11:27 AM, Ari Jolma <ari.jolma at gmail.com> wrote:
> 24.11.2016, 18:01, Even Rouault kirjoitti:
> Could be worth fixing that if that cause issues (apparently in your use
> case at least), but I'd be interested by information of what is the
> standard/recommanded/best-practice-in-the-industry/etc... formulas to use
> for the mapping between the [0,255] and [0,65535] ranges.
> At least in the GTK circles it seems to be a standard practice to use the
> 257 as the scaling factor. See for example
> http://gtk2-perl.sourceforge.net/doc/pod/Gtk2/Gdk/Color.html
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161125/45f1a4a9/attachment.html>
