[gdal-dev] laundering of field's names in GDAL
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Sun Nov 27 09:23:54 PST 2016
I believe that the answer in gis.stackexchange
http://gis.stackexchange.com/questions/219177/can-colon-character-be-used-in-shapefile-field-names
is correct. The dBase III format that is used in shapefiles for storing
attributes does not accept colon in field names, and GDAL does not want to
write invalid shapefiles.
Laundering has an effect if data are converted into PostGIS, Spatialite or
other formats for which both "attribute_name" and "attribute:name" are valid
as field names.
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-laundering-of-field-s-names-in-GDAL-tp5297549p5297578.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
