[gdal-dev] No XLSX fields in v2.1.2
Even Rouault
even.rouault at spatialys.com
Mon Nov 28 14:21:04 PST 2016
There was indeed some changes in the XLSX driver for 2.1.2 to fix some issues. I guess what
you observe is an unfortunate regression linked to those changes. Would you mind filing a
ticket in https://trac.osgeo.org/gdal/newticket about that ? Thanks
Even
> All,
> Just wondering if someone could sanity check this possible bug for me. I'm
> trying to read data from a Excel spreadsheet. It was scripted and working
> fine on GDAL 2.1.1 but is now failing on GDAL 2.1.2.
> I've attached the spreadsheet, it is generated by our back office system
> (Microsoft SQL Server Reporting Services (SSRS)). I've also noticed that
> if I open the spreadsheet up in Excel and resave GDAL can then read it
> again.
> Any ideas?
> Many thanks,
> Rob
> OLD VERSION
> > ogrinfo --version
> >> GDAL 2.1.1, released 2016/07/07
> *(also tested on GDAL 1.11.1, released 2014/09/24)
> > ogrinfo -so -al -ro Interactive_mapping_pet_shop_licences.xlsx --config
> > OGR_XLSX_HEADERS FORCE>
> >> INFO: Open of `Interactive_mapping_pet_shop_licences.xlsx'
> >> using driver `XLSX' successful.
> >> Layer name: Interactive mapping - Pet Shop
> >> Geometry: None
> >> Feature Count: 21
> >> Layer SRS WKT:
> >> (unknown)
> >> Licence ref: String (0.0)
> >> UPRN: String (0.0)
> >> Easting: String (0.0)
> >> Northing: String (0.0)
> >> Premises Id: Integer (0.0)
> >> Business Name: String (0.0)
> >> Address: String (0.0)
> >> Ward Description: String (0.0)
> >> 1st licensed: String (0.0)
> >> Licence expiry: String (0.0)
> NEW VERSION
> > ogrinfo --version
> >> GDAL 2.1.2, released 2016/10/24
> >> Geometry: None
> >> Feature Count: 0
> >> Layer SRS WKT:
> >> (unknown)
> DISCLAIMER: The information contained in this communication/message from
> Rob.Langford at salford.gov.uk sent on Mon Nov 28 16:07:38 2016 is
> confidential. It is intended solely for the addressee(s)
> gdal-dev at lists.osgeo.org
> Access to this message by anyone else is unauthorised. If you are not the
> intended recipient, any disclosure, copying, or distribution of the
> message, or any action or omission taken by you in reliance on it, is
> prohibited and may be unlawful. As a public body, Salford City Council may
> be required to disclose this email [or any response to it] under the
> Freedom of Information Act 2000, unless the information in it is covered by
> one of the exemptions in the Act. Please immediately contact the sender,
> Rob.Langford at salford.gov.uk if you have received this message in error.
> For the full disclaimer please access http://www.salford.gov.uk/e-mail.
> Thank you.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161128/2e7e6955/attachment-0001.html>
