[gdal-dev] ogr2ogr - exclude table option?
Andreas Neumann a.neumann at carto.net
Wed Nov 30 12:11:14 PST 2016
Hi Even,
Thanks. I will use the 'ogrinfo your.gpkg -sql "DROP TABLE table_name"'
trick for now.
One thing though: I noticed that the filesize doesn't really shrink. Is
there a way to compact/vacuum the geopackage after removal of the table?
The table I remove is rather big - so it would have quite an effect on
the filesize.
On the blacklist / exclude table options for table transfer from Postgis
to GPKG - can you please send me an estimate/quote offlist? Depending on
how much this costs, I would be interested in paying for that.
Thanks a lot,
Andreas
Am 30.11.2016 um 18:05 schrieb Even Rouault:
> On mercredi 30 novembre 2016 16:21:42 CET Neumann, Andreas wrote:
> > Hi,
> > I want to convert a whole Postgis schema to a geopackage. This works
> > fine with
> > ogr2ogr -f GPKG av_1700.gpkg PG:'dbname=dbname host=localhost
> > schemas=schemaname'
> > Now - my problem is that the schema contains 64 tables and I want to
> > convert all tables except one table.
> > Is there a trick with an exclude option? I know that I can list all
> > tables that I want to convert in the sense of a white list with
> > 'tables=tab1,tab2,tab3', etc. - but this is complicated for this many
> > tables.
> > I hope that there is / could be some black list option - or the
> > possibility of specifying a pattern for selection the tables to be
> > converted.
> Andreas,
> There's no such option (there's no real technical hurdle if one would
> want to add one, but one can wonder how common this use case is)
> The easiest way currently would be to drop the unwished tables after
> the import : ogrinfo your.gpkg -sql "DROP TABLE table_name". Since
> GDAL 2.1.2, this not only drops the table but also all references to
> it in GPKG system tables.
> You could also do a tiny script to list the tables and remove the
> one(s) you don't want from the list before calling ogr2ogr /
> gdal.VectorTranslate()
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161130/2b9f7e3f/attachment.html>
