[gdal-dev] GPKG: Drop table but how to drop the rest?
Even Rouault even.rouault at spatialys.com
Wed Oct 5 13:47:56 PDT 2016
Le jeudi 29 septembre 2016 13:13:17, Even Rouault a écrit :
> Hi Jukka,
> > I wonder if it could be possible to do something like "DROP CASCADING" in
> > GeoPackage and delete the spatial index by the same.
> I will work in a short term on this (as well as renaming columns)
Jukka, I wrote too fast and now realize that
GDALGeoPackageDataset::DeleteLayer() is already implemented in fact (renaming
is not) and available through the API. It is just that the DELLAYER: shortcut
is not available.
http://www.spatialys.com
