[gdal-dev] Need suggestion on clipping vectors in batch
    Margherita Di Leo
    diregola at gmail.com
    Thu Oct  6 05:47:05 PDT 2016
Dear Even,
On Wed, Oct 5, 2016 at 8:53 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Tiny Python script with GDAL 2.1 :
> from osgeo import gdal
> src_ds = gdal.OpenEx('your.shp')
> lyr = src_ds.GetLayer(0)
> minx, maxx, miny, maxy = lyr.GetExtent()
> # Note the different order of bounds between previous and next line
> gdal.VectorTranslate("out.shp", src_ds, \
>  spatFilter=(minx + DX,miny +DY,maxx-DX, maxy-DX))
> Many thanks!
I'm having some headache because I have gdal 1.11 installed system-wide,
coming from package, so I installed gdal 2.2 in local in $HOME/opt/gdal
(=$GDAL_INSTALL_DIR)
in my terminal I run:
$ export PATH=$GDAL_INSTALL_DIR/bin:$PATH
$ export LD_LIBRARY_PATH=$GDAL_INSTALL_DIR/lib:$LD_LIBRARY_PATH
$ export GDAL_DATA=$GDAL_INSTALL_DIR/share/gdal
$ gdalinfo --version
GDAL 2.2.0dev, released 2016/99/99
$ python
>>> gdal.VersionInfo()
'1110400'
Also, in sys.path() the $GDAL_INSTALL_DIR is listed correctly... I'm at a
dead end :-/
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161006/f974001e/attachment.html>
