[gdal-dev] GDALOpenInternal Problem Opening specific HDF5 bands
    Even Rouault
    even.rouault at spatialys.com
    Mon Oct 10 06:44:13 PDT 2016
Le lundi 10 octobre 2016 15:20:08, Michele Cleary a écrit :
> I'm trying to open an HDF5 file, specific bands, but GDAL is giving an
> error message:
> > "'HDF5:C:\pathToFile\pathToFile/filename.h5://ImageData/B4' does not>
> > exist in the file system and is not recognized as a supported data set>
> > name"
> I got the error message after the GDALOpenInternal call using
> CPLGetLastErrorMsg().  I can't step into GDALOpenInternal (with Visual
> Studio) because we don't have GDAL source cpp file; just h file that came
> with the package, unless I'm searching for the wrong file name. The string
> for the ConnectionString parameter for GDALOpenInternal is shown in the
> quotes above. I found [qgis polygonize error 4 "file does not exist in the
> file system"], but they said it was because of using non-ascii characters
> in file path string.  I didn't see any other pertinent info on this error
> message. We need to access the specific band of the HDF5 file.  I noticed
> that our slashes in the path are showing in different directions, but I'm
> not sure that would be the issue here.  We have both windows and linux
> OS's.  This error was seen on windows os. We used (gdalinfo.exe
> filename.h5) and do see that the B4 exists there. Using the string,
> HDF5:"C:\pathToFile\filename.h5"://ImageData/B2, didn't work for
> openInternal with GDAL.
> I saw  (gdal.org/gdal_tutorial.html), which gives an example to open a band
> after a GDALOpen, but it seems that it's supposed to work with
> GDALOpenInternal also according to my co-workers. We just don't have a
> good example of the connection string to get it working with
> GDALOpenInternal since we don't have access to that part of the code that
> does it. They want me to focus on using GDALOpenInternal.
> I'm
> seeing lists.alioth.debian.org/pipermail/pkg-grass-devel/2012-November/…
> , which gives me hope, but doesn't have a good example. I saw this which
> could be an example, although it isn't using a path, but I'm not sure:
> gdalwarp HDF4_SDS:ASTER_L1B:"pg-PR1B0000-2002031402_100_001":2
> pg-PR1B0000-2002031402_100_001_2.tif
> My question is, what format for the connection string do I need to use
> GDALOpenInternal, if it's not what I show for the two things I tried
> above?
You should try first
gdalinfo c:\pathToFile\filename.h5
and then, if that opens, try accessing the subdataset it will report. The
expected syntax is like HDF5:"c:\pathToFile\filename.h5":subdataset_name
Since you seem to mention that the path contains non ASCII characters, I
wouldn't be surprise if that didn't work correctly on Windows. You should
perhaps try making sure your path is encoded in the current ANSI code page of
your system since that's probably what the HDF5 API expects.
Would probably make sense for GDAL to recode from UTF-8 to current ANSI code
page automagically as it does in the XLS driver:
#ifdef _WIN32
    if( CPLTestBool( CPLGetConfigOption( "GDAL_FILENAME_IS_UTF8", "YES" ) ) )
        pszName = CPLRecode( pszFilename, CPL_ENC_UTF8, CPLString().Printf(
"CP%d", GetACP() ) );
    else
        pszName = CPLStrdup( pszFilename );
#else
#endif
That assumes that the accentued characters you need can be expressed in the
current ANSI code page, otherwise you'll have to move the file elsewhere
Even
http://www.spatialys.com
