[gdal-dev] Need suggestion on clipping vectors in batch
Margherita Di Leo
diregola at gmail.com
Tue Oct 11 08:44:43 PDT 2016
On Fri, Oct 7, 2016 at 12:00 PM, Margherita Di Leo <diregola at gmail.com>
wrote:
> Dear Even, all,
> On Thu, Oct 6, 2016 at 3:25 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Le jeudi 06 octobre 2016 14:47:05, Margherita Di Leo a écrit :
>> > Dear Even,
>> Try:
>> export PYTHONPATH=$GDAL_INSTALL_DIR/lib/python2.7/site-packages
>> ( adapt the path to the python version you use)
> It didn't help.
> Sorry to go off-topic from original subject but I really cannot understand
> what's wrong with my work flow.
> I write down every single step:
> # Download source
> cd $HOME/opt
> svn checkout https://svn.osgeo.org/gdal/trunk/gdal gdal-source
> # Create bin dir
> mkdir -p $HOME/opt/gdal-bin
> export GDAL_INSTALL_DIR=$HOME/opt/gdal-bin
> # set environment variables for current session
> export PATH=$GDAL_INSTALL_DIR/bin:$PATH
> export LD_LIBRARY_PATH=$GDAL_INSTALL_DIR/lib:$LD_LIBRARY_PATH
> export GDAL_DATA=$GDAL_INSTALL_DIR/share/gdal
> # compile gdal in local folder
> cd $HOME/opt/gdal-source
> ./configure --prefix=$GDAL_INSTALL_DIR
> make
> make install
> # setting up python environment
> cd $HOME/opt/gdal-source/swig/python
> python setup.py build
> mkdir -p $GDAL_INSTALL_DIR/lib64/python2.7/site-packages/
> export PYTHONPATH=$GDAL_INSTALL_DIR/lib64/python2.7/site-packages:
> $PYTHONPATH
> python setup.py install --prefix=$GDAL_INSTALL_DIR
> # Check if works
> python
> from osgeo import gdal
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> File "osgeo/__init__.py", line 21, in <module>
> _gdal = swig_import_helper()
> File "osgeo/__init__.py", line 13, in swig_import_helper
> import _gdal
> ImportError: No module named _gdal
> Outside python:
> gdalinfo --version
> GDAL 2.2.0dev, released 2016/99/99
I don't know what was happening, but now this works. Sorry for the noise.
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161011/8aae1590/attachment-0001.html>
