[gdal-dev] Wrongly identified SQLITE_BLOB as geomtry
Christian Urich christian.urich at gmail.com
Mon Oct 24 00:42:31 PDT 2016
Hi all,
I have created a binary blob in a spatialite db. If I try to open the db the column is wrongly identified as geometry which causes all kinds of problems.
Is there a way to force gdal to only consider the geometry_columns table?
Cheers
Christian
