[gdal-dev] gdal_translate to Rasterlite and (missing) srs
Even Rouault even.rouault at spatialys.com
Mon Oct 24 09:22:47 PDT 2016
Helmut,
> is this intentional that there is no srs by a simple gdal_translate of a
> geotiff to a Rasterlite db?
From what I can see the driver doesn't handle adding a new entry in the
spatial_ref_sys table if there's no AUTHORITY node, such as in your use case.
From what I can see, it also probably doesn't properly support creating
entries in spatial_ref_sys with Spatialite 4 layout (the driver has been
likely developped during Spatialite 3 era)
It is "intentional" in the meaning that this wasn't implemented, but could
potentially be added. Could be worth a ticket in Trac.
> maybe there is some other command line option related to Rasterlite db
> which I'm missing?
No, the workaround is the one you found. Make sure a EPSG code is attached to
the input dataset, or assign it explictly
Even
http://www.spatialys.com
