[gdal-dev] Wrongly identified SQLITE_BLOB as geomtry
Christian Urich
christian.urich at gmail.com
Mon Oct 24 16:49:54 PDT 2016
Hi Even and Jukka,
Thanks for the quick fixes!
Just tested the code from the master and it works for my use case.
Cheers
Christian
On 24 October 2016 at 11:33:17 pm, Even Rouault (even.rouault at spatialys.com)
wrote:
Le lundi 24 octobre 2016 14:10:34, Christian Urich a écrit :
> Hi,
> will do.
> I run into another problem. The update statement for multiple geometry
> fails.
> ERROR 1: In SetFeature(): sqlite3_prepare(UPDATE 'timeseries' SET "data"
> ?"GEOMETRY" = ?,"end" = ?,"start" = ?,"station_id" = ?,"timestep" =
> ?,"type" = ?,"s" = ? WHERE "ogc_fid" = 1):
> near ""GEOMETRY"": syntax error
> Looks like a comma is missing. Looking at the code my guess is
> gdal/gdal/ogr/ogrsf_frmts/sqlite/ogrsqlitetablelayer.cpp line 2640 misses
a
> if( bNeedComma )
> osCommand += ",";
Good catch! Thanks. Fixed per https://trac.osgeo.org/gdal/ticket/6696
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161024/b903989f/attachment.html>
