[gdal-dev] Need some information please
Even Rouault
even.rouault at spatialys.com
Tue Oct 25 08:06:50 PDT 2016
Le mardi 25 octobre 2016 15:40:52, Renison a écrit :
> I am using GDAL 64 bit with map server compiled with MSCV 1600. I am trying
> to generate a tab file and when I pass a style string like this string
> style = @"SYMBOL(c:#00FF00,o:#00FF00,id:""mapinfo-sym-64,ogr-sym-7"")"; it
> always seems to ignore the "o". My goal is to get rid of the border around
> the symbol by passing the outline as the same color.
My understanding of the code is that the outline color is ignored when writing
MapInfo style. I haven't dug up to know if it is just code that is missing or
if there's indeed no way to set that in .tab format (support on the read side
is also missing)
http://www.spatialys.com
