[gdal-dev] gdalwarp error 6 issues
Zoltan Szecsei
zoltans at geograph.co.za
Thu Sep 1 08:05:37 PDT 2016
I've been struggling to get some 3200 orthos mosaicked and tiled.
They are very old and have really bad projection definitions, pixel
sizes and metadata funnies.
I'm down to the last 261, and have hit a brick wall.
Given that gdalwarp works on this image when I leave out s_srs and t_srs
(see below), I'm not sure if this is a bug related hiccough or a proj issue.
I have compiled the latest "GDAL 2.1.1, released 2016/07/07" myself, on
Ubuntu 16.04.1 Desktop: Linux gl05 4.4.0-36-generic #55-Ubuntu SMP Thu
Aug 11 18:01:55 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
I get the following error from gdalwarp:
ERROR 6: Unable to load PROJ.4 library (libproj.so), creation of
OGRCoordinateTransformation failed.
I have tried various different gdalwarp parameters - even leaving
gdalwarp to sense in input projection and me only specifying the output
projection.
If I leave out both s_srs and t_srs then gdalwarp does work but
obliviously does not reproject to Lo19.
I have even tried feeding the output of this redundant gdalwarp into a
gdalwarp with t_srs, but no success.
Specifying only t_srs (as above) on many other orthos on Lo17 & Lo21
does work so it is likely that the way this projection is embedded in
this ortho is the problem.
I have tried stripping it out with gdal_edit.py but haven't gotten that
right yet.
Anyone with pointers or ideas on this?
My last effort before email this list is below, as is the gdalinfo output.
Thanks in advance,
Zoltan
gdalwarp -s_srs '+proj=tmerc +lat_0=0 +lon_0=21 +k=1 +x_0=0 +y_0=0
+datum=Hartebeesthoek94 +units=m +no_defs' \
-t_srs '+proj=tmerc +lat_0=0 +lon_0=19 +k=1 +x_0=0 +y_0=0
+datum=WGS84 +units=m +no_defs' \
-r cubicspline -multi -overwrite -of GTiff -co TFW=YES -co
COMPRESS=JPEG -co JPEG_QUALITY=75 -tr 0.75 -0.75 \
/mnt/sdb1/used_images/dwa_2000/3220/3220CC01.tif \
/mnt/sda1/gisdata/raster/used_2016/dwa_2000/3220/3220CC01.tif
gdalinfo /mnt/sdb1/used_images/dwa_2000/3220/3220CC01.tif
Driver: GTiff/GeoTIFF
Files: /mnt/sdb1/used_images/dwa_2000/3220/3220CC01.tif
Size is 6729, 7720
Coordinate System is:
LOCAL_CS[" Geocoding information not available Projection Name = WGS
1984 Lo21 Units = meters GeoTIFF Units = meters",
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-93872.189308887900552,-3625321.216973003931344)
Pixel Size = (0.750000000000000,-0.750000000000000)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_DOCUMENTNAME=hetotiff
TIFFTAG_IMAGEDESCRIPTION=ER Mapper 6.4 hetotiff
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
TIFFTAG_SOFTWARE=IMAGINE TIFF Support
Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: etif.c $ $Revision: 1.9.1.3 $ $Date: 2002/07/29 15:39:06EDT $
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( -93872.189,-3625321.217)
Lower Left ( -93872.189,-3631111.217)
Upper Right ( -88825.439,-3625321.217)
Lower Right ( -88825.439,-3631111.217)
Center ( -91348.814,-3628216.217)
Band 1 Block=6729x1 Type=Byte, ColorInterp=Red
Band 2 Block=6729x1 Type=Byte, ColorInterp=Green
Band 3 Block=6729x1 Type=Byte, ColorInterp=Blue
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160901/ef14bf6d/attachment.html>
