[gdal-dev] gdalwarp error 6 issues
Zoltan Szecsei
zoltans at geograph.co.za
Thu Sep 1 10:41:18 PDT 2016
Hi Even,
Long time no chat - Hope all is well with you. :-)
When compiling GDAL, I just used all defaults, so it was just a
"straight" ./configure.
The errant images are ENU on WGS84 Lo17 and Lo21, and I need to
reproject to same but Lo19
(They are on the fringes of Lo19)
I tried gdal_edit.py to force a better representation of where those
images are, but no luck.
I used variations of the s-srs line below (ie: replacing HBK94 with
WGS84) and also 1 or 2 EPSG codes - but I was guessing the EPSG ones.
Is there not a way to stamp out the existing proj info, and replace with
the desired source projection stanza using gdal_edit.py?
I've got a batch run in at the moment so don't want to fiddle until that
has finished.
I will also recompile with --with-static-proj4.
Thanks for the pointers.
Regards,
Zoltan
On 2016-09-01 18:40, Even Rouault wrote:
> Zoltan,
>> Hi,
>> I've been struggling to get some 3200 orthos mosaicked and tiled.
>> They are very old and have really bad projection definitions, pixel
>> sizes and metadata funnies.
>> I'm down to the last 261, and have hit a brick wall.
>> Given that gdalwarp works on this image when I leave out s_srs and t_srs
>> (see below), I'm not sure if this is a bug related hiccough or a proj
>> issue.
>> I have compiled the latest "GDAL 2.1.1, released 2016/07/07" myself, on
>> Ubuntu 16.04.1 Desktop: Linux gl05 4.4.0-36-generic #55-Ubuntu SMP Thu
>> Aug 11 18:01:55 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
>> I get the following error from gdalwarp:
>> ERROR 6: Unable to load PROJ.4 library (libproj.so), creation of
>> OGRCoordinateTransformation failed.
> Hum, if you get this message, then reprojection should never succeed. How did
> you compile GDAL with ./configure --with-static-proj4 or without it ? If
> without it, you must be sure to have the development package of proj installed
> so that proj.so links to proj.so.1 or proj.so.9 or whatever the soname of your
> proj is.
>> I have tried various different gdalwarp parameters - even leaving
>> gdalwarp to sense in input projection and me only specifying the output
>> projection.
>> If I leave out both s_srs and t_srs then gdalwarp does work but
>> obliviously does not reproject to Lo19.
>> I have even tried feeding the output of this redundant gdalwarp into a
>> gdalwarp with t_srs, but no success.
>> Specifying only t_srs (as above) on many other orthos on Lo17 & Lo21
>> does work so it is likely that the way this projection is embedded in
>> this ortho is the problem.
> Yes, the way ER Mapper encodes the projection is non-standard and thus GDAL
> reports a LOCAL_CS that cannot be used to automatically get a proj.4 string.
> GDAL has some handling for some of those non-standard encodings, but not for
> your ones, so overriding it with -s_srs is needed.
>> I have tried stripping it out with gdal_edit.py but haven't gotten that
>> right yet.
>> Anyone with pointers or ideas on this?
> +datum=Hartebeesthoek94 is not recognized by proj.4.
> Why not using EPSG:2049 instead or the proj.4 expension ? I also see that
> gdalsrsinfo EPSG:2049 expands to
> PROJ.4 : '+proj=tmerc +lat_0=0 +lon_0=21 +k=1 +x_0=0 +y_0=0 +axis=wsu
> +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs '
> So note the +axis=wsu parameter for the south-orientated variant
> Or perhaps this doesn't make sense in your context of producing a GeoTIFF, so
> in that case you might just want to use the above proj.4 string without
> +axis=wsu. Note that for proj the Hartebeesthoek94 datum is equivalent to
> WGS84.
> Even
>> My last effort before email this list is below, as is the gdalinfo output.
>> Thanks in advance,
>> Zoltan
>> gdalwarp -s_srs '+proj=tmerc +lat_0=0 +lon_0=21 +k=1 +x_0=0 +y_0=0
>> +datum=Hartebeesthoek94 +units=m +no_defs' \
>> -t_srs '+proj=tmerc +lat_0=0 +lon_0=19 +k=1 +x_0=0 +y_0=0
>> +datum=WGS84 +units=m +no_defs' \
>> -r cubicspline -multi -overwrite -of GTiff -co TFW=YES -co
>> COMPRESS=JPEG -co JPEG_QUALITY=75 -tr 0.75 -0.75 \
>> /mnt/sdb1/used_images/dwa_2000/3220/3220CC01.tif \
>> /mnt/sda1/gisdata/raster/used_2016/dwa_2000/3220/3220CC01.tif
>> gdalinfo /mnt/sdb1/used_images/dwa_2000/3220/3220CC01.tif
>> Driver: GTiff/GeoTIFF
>> Files: /mnt/sdb1/used_images/dwa_2000/3220/3220CC01.tif
>> Size is 6729, 7720
>> Coordinate System is:
>> LOCAL_CS[" Geocoding information not available Projection Name = WGS
>> 1984 Lo21 Units = meters GeoTIFF Units = meters",
>> UNIT["metre",1,
>> AUTHORITY["EPSG","9001"]]]
>> Origin = (-93872.189308887900552,-3625321.216973003931344)
>> Pixel Size = (0.750000000000000,-0.750000000000000)
>> Metadata:
>> AREA_OR_POINT=Area
>> TIFFTAG_DOCUMENTNAME=hetotiff
>> TIFFTAG_IMAGEDESCRIPTION=ER Mapper 6.4 hetotiff
>> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
>> TIFFTAG_SOFTWARE=IMAGINE TIFF Support
>> Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
>> @(#)$RCSfile: etif.c $ $Revision: 1.9.1.3 $ $Date: 2002/07/29 15:39:06EDT $
>> TIFFTAG_XRESOLUTION=1
>> TIFFTAG_YRESOLUTION=1
>> Image Structure Metadata:
>> INTERLEAVE=PIXEL
>> Corner Coordinates:
>> Upper Left ( -93872.189,-3625321.217)
>> Lower Left ( -93872.189,-3631111.217)
>> Upper Right ( -88825.439,-3625321.217)
>> Lower Right ( -88825.439,-3631111.217)
>> Center ( -91348.814,-3628216.217)
>> Band 1 Block=6729x1 Type=Byte, ColorInterp=Red
>> Band 2 Block=6729x1 Type=Byte, ColorInterp=Green
>> Band 3 Block=6729x1 Type=Byte, ColorInterp=Blue
