[gdal-dev] minor correction for drv_libkml.html [bash-script] neeted
Mark Johnson
mj10777 at googlemail.com
Sat Sep 10 03:05:36 PDT 2016
While adding support for LIBKML to my gdal configuration
- I attempted to use the sample bash-script to insure that it worked
correctly
It failed with a syntax error, caused in line 3 of the script:
> #!/bin/bash
> # Copyright (c) 2010, Brian Case
> * Copyright (c) 2010-2014, Even Rouault
> # Permission
> needs to be changed to:
> #!/bin/bash
> # Copyright (c) 2010-2014, Even Rouault
> # Permission
> to run without error.
Mark Johnson, Berlin Germany
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160910/3bd27e2a/attachment.html>
