[gdal-dev] Problem reading WAFS GRIB2 file with gdal
Pierre Leman
pierrelem at gmail.com
Wed Sep 14 08:09:18 PDT 2016
Hi Even,
Thanks for handling this problem so fast it's perfect.
Any information about the GDAL 2.2 release date ?
Pierre
2016-09-14 16:16 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> Pierre,
> > A bug seems to be already opened for this error :
> > https://trac.osgeo.org/gdal/ticket/5768
> I had a look and just added support for that kind of products in GDAL
> trunk.
> The issue was that Template 4.15 (
> http://www.nco.ncep.noaa.gov/pmb/docs/grib2/grib2_temp4-15.shtml ) used
> for
> bands 4-37 wasn't supported before.
> I've also refreshed the GRIB tables used to get parameter names from latest
> degrib v2.0.3
> Now you get:
> $ gdalinfo WAFS_blended_2016090700f06.grib2
> Driver: GRIB/GRIdded Binary (.grb)
> Files: WAFS_blended_2016090700f06.grib2
> Size is 288, 145
> Coordinate System is:
> GEOGCS["Coordinate System imported from GRIB file",
> DATUM["unknown",
> SPHEROID["Sphere",6371229,0]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]]
> Origin = (-0.625000000000000,90.625000000000000)
> Pixel Size = (1.250000000000000,-1.250000000000000)
> Corner Coordinates:
> Upper Left ( -0.6250000, 90.6250000) ( 0d37'30.00"W, 90d37'30.00"N)
> Lower Left ( -0.6250000, -90.6250000) ( 0d37'30.00"W, 90d37'30.00"S)
> Upper Right ( 359.375, 90.625) (359d22'30.00"E, 90d37'30.00"N)
> Lower Right ( 359.375, -90.625) (359d22'30.00"E, 90d37'30.00"S)
> Center ( 179.3750000, 0.0000000) (179d22'30.00"E, 0d 0' 0.01"N)
> Band 1 Block=288x1 Type=Float64, ColorInterp=Undefined
> Description = 0[-] RESERVED(11) (Reserved)
> Metadata:
> GRIB_COMMENT=ICAO Standard Atmosphere Reference Height [m]
> GRIB_ELEMENT=ICAHT
> GRIB_FORECAST_SECONDS=21600 sec
> GRIB_PDS_PDTN=0
> GRIB_PDS_TEMPLATE_NUMBERS=3 3 2 0 96 0 0 0 1 0 0 0 6 11 0 0 0 0 0 255
> 0 0
> 0 0 0
> GRIB_REF_TIME= 1473206400 sec UTC
> GRIB_SHORT_NAME=0-RESERVED(11)
> GRIB_UNIT=[m]
> GRIB_VALID_TIME= 1473228000 sec UTC
> [...snip...]
> Band 4 Block=288x1 Type=Float64, ColorInterp=Undefined
> Description = 70000[Pa] ISBL="Isobaric surface"
> Metadata:
> GRIB_COMMENT=In-Cloud Turbulence [%]
> GRIB_ELEMENT=CTP
> GRIB_PDS_PDTN=15
> GRIB_PDS_TEMPLATE_NUMBERS=19 21 2 0 96 0 0 0 1 0 0 0 6 100 0 0 1 17 112
> 255 0 0 0 0 0 0 3 1
> GRIB_SHORT_NAME=70000-ISBL
> GRIB_UNIT=[%]
> [... snip ... ]
> Band 37 Block=288x1 Type=Float64, ColorInterp=Undefined
> Description = 30000[Pa] ISBL="Isobaric surface"
> Metadata:
> GRIB_COMMENT=Icing [%]
> GRIB_ELEMENT=ICIP
> GRIB_PDS_PDTN=15
> GRIB_PDS_TEMPLATE_NUMBERS=19 20 2 0 96 0 0 0 1 0 0 0 6 100 0 0 0 117 48
> 255 0 0 0 0 0 2 3 1
> GRIB_SHORT_NAME=30000-ISBL
> GRIB_UNIT=[%]
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160914/43e627d7/attachment.html>
