[gdal-dev] SQLite driver?
Joaquim Luis jluis at ualg.pt
Wed Sep 14 10:35:46 PDT 2016
Hmm, several (weird) things.
1. I'm using  GnuWin ports for unix commands. And:
     - this works
           gdalinfo --formats | sort
     - this not (output is empty)
           ogfinfo --formats | sort
    Same thing for 'grep'
2. To check I'm using gisinternals and same thing as my build.
    ogrinfo --formats
    shows no SQLite driver
3. The program I'm trying to build/run crashes at this line
     https://github.com/osmcode/osmcoastline/blob/master/include/gdalcpp.hpp#L132
     (no idea why it crashes) apparently because it doesn't find the SQLite
driver (driver_name == 'SQLite')
> ogrinfo --formats | grep -i lite
>  SQLite -vector- (rw+v): SQLite / Spatialite
> On Wed, Sep 14, 2016 at 9:32 AM, Joaquim Luis <jluis at ualg.pt> wrote:
>> Sorry Even that you are bombed with so many questions.
>> I have (re)build GDAL with sqlite and can confirm with The (Dependency)
>> Walker that the sqlite3.dll is a gdal.dll dependency. However,
>> gdalinfo --formats
>>  Rasterlite -raster- (rws): Rasterlite
>>  SAFE -raster- (rov): Sentinel-1 SAR SAFE Product
>>  SAR_CEOS -raster- (rov): CEOS SAR Image
>>  SDTS -raster- (rov): SDTS Raster
>>  SENTINEL2 -raster- (rovs): Sentinel 2
>>  SGI -raster- (rw+): SGI Image File Format 1.0
>>  SRTMHGT -raster- (rwv): SRTMHGT File Format
>>  TIL -raster- (rov): EarthWatch .TIL
>> does not show the SQLite driver and indeed a program that I'm building
>> that needs to link with GDAL (osmcoastline) crashes when it doesn't
>> find >>that driver.
>> Joaquim
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160914/3b1b28bb/attachment.html>
