[gdal-dev] Feasibility of expanding VRT schema to allow users to specify X/Y dimension for HDF data?
    H. Joe Lee
    hyoklee at hdfgroup.org
    Fri Sep 16 09:50:53 PDT 2016
Hi, Even!
I'm making some progress in utilizing OpenOptions to modify HDF drivers.
For automated testing of the new HDF drivers, should I use
gdal.OpenEx() like below in gor2vrt.py?
src_ds = gdal.OpenEx( infile, gdal.OF_VECTOR, open_options = openoptions )
Or does gdal.Open() also support open_options argument?
HDF:Antifragile Solution for Elastic Bigdata Analytics
On Fri, Aug 5, 2016 at 2:59 AM, Even Rouault <even.rouault at spatialys.com> wrote:
> Frank,
> From what I understand from Joe's needs, it looks like simple transposing of a
> 2D raster wouldn't be enough. Here we would need to "transpose" pixels
> scattered through different subdatasets due to the Nd > 2 dimensionality of the
> original dataset, which would be impractical to express at the VRT level, and
> likely inefficient.
> Something I've thought about would be to make Nd > 2 rasters native objects at
> the GDAL level, but this would have likely deep implications on the code base
> and should be considered carefully, and would be of interest for a limited set
> of drivers (netCDF, HDF4, HDF5, Rasdaman).
> Even
>> Brian / Even,
>> Certainly it is desirable for the HDF (and perhaps other super
>> flexible formats like netcdf) to support an open option to select
>> alternative axes.  But the ability to transpose a dataset could also
>> be quite valuable in the VRT driver to "fix" any input transposed
>> dataset.
>> I'm also not entirely certain why one couldn't supply an appopriately
>> transposed geotransform to accomplish something similar.  This could
>> be done without any code changes in the existing VRT format.
>> Best regards,
>> Frank
>> On Thu, Aug 4, 2016 at 3:32 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> > On Thursday 04 August 2016 16:31:25 H. Joe Lee wrote:
>> >> Hi,
>> >>   My name is Joe Lee and I'm very interested in improving GDAL's
>> >> capability to access NASA HDF4/HDF5 data so that users can work with
>> >> HDF easily through GDAL. For example, my goal is to allow users to
>> >> translate any HDF data into GeoTIFF via gdal_translate.
>> >>   I've worked with diverse NASA HDF products and provided solution for
>> >> visualizing data correctly through Python/MATLAB/IDL/NCL [1] and I
>> >> know that many products, other than HDF-EOS, may not work well with
>> >> GDAL because HDF is flexible and NASA data producers do not
>> >> necessarily follow the conventions that GDAL uses.
>> >>   By default, GDAL HDF4/HDF5 driver uses the following convention for
>> >> unknown products.
>> >>     For HDF4 (frmts/hdf4/hdf4imagedataset.cpp):
>> >>     // Search for the starting "X" and "Y" in the names or take
>> >>     // the last two dimensions as X and Y sizes
>> >>     iXDim = nDimCount - 1;
>> >>     iYDim = nDimCount - 2;
>> >>   For HDF5 (frmts/hdf5/hdf5imagedataset.cpp):
>> >>     int     GetYIndex() const { return IsComplexCSKL1A() ? 0 : ndims - 2;
>> >>     int     GetXIndex() const { return IsComplexCSKL1A() ? 1 : ndims - 1;
>> >>  The above code works well as long as Unknown HDF product follows the
>> >> above convention. However, in reality, HDF data can have an arbitrary
>> >> order in terms of Band, X and Y dimension like this:
>> >>   dset4D[XDim=360][YDim=180][Band1=2][Band2=3]
>> >>   dimindex:    0                      1            2             3
>> >>   Since ndims=4, ndims-2 becomes 2 and ndims-1=3. In such case, GDAL
>> >> generates 360x180 bands of 2x3 images, instead of the desired 2x3
>> >> bands of 360x180 images.
>> >>   Thus, I'm wondering if GDAL can expand VRT schema so that VRT allows
>> >> users to specify the correct dimension index because specifying
>> >> dimension order for each different NASA product in [1]  is
>> >> impractical. For example, I'd like suggest a new tag like
>> >> "SourceDimension" like below:
>> >>   <VRTRasterBand dataType="UInt16" band="1">
>> >>   <SimpleSource>
>> >>     <SourceFilename
>> >> relativeToVRT="0">HDF4_SDS:UNKNOWN:"DATA_WITH_4D_DATASET.hdf":7</SourceFi
>> >> len ame> <SourceDimension RasterXDim="0" RasterYDim="1" />
>> >>     <SourceBand>1</SourceBand>
>> >>     <SourceProperties RasterXSize="360" RasterYSize="180"
>> >> DataType="UInt16" BlockXSize="360" BlockYSize="180" />
>> >>   </SimpleSource>
>> >> </VRTRasterBand>
>> >>   Once user specifies correct dimensions by editing VRT, it can be
>> >> used by GDAL HDF4/HDF5 drivers and the HDF drivers read the data
>> >> correctly for GDAL's image buffer.
>> >>   Do you think it's right and feasible approach to solve wrong X/Y
>> >> dimension order problem? Or do you have any other existing solution
>> >> that can mitigate this problem in GDAL? The GEE project team has
>> >> experimented the idea by creating another separate XML file [2] but I
>> >> think it's time to sync with GDAL development team and come up with
>> >> the most elegant solution. In my opinion, VRT looks best and I wish
>> >> GDAL development team can give me some feedback on this idea.
>> > Joe,
>> > I would rather suggest to add open options to the drivers and pass them
>> > with the exiting VRT OpenOptions element, rather than adding a new
>> > element in the VRT that would be specific of a few drivers
>> >  <SimpleSource>
>> >     <SourceFilename>
>> > relativeToVRT="0">HDF4_SDS:UNKNOWN:"DATA_WITH_4D_DATASET.hdf":7</SourceFil
>> > ename>>
>> >    <OpenOptions>
>> >       <OOI key="RASTERXDIM">0</OOI>
>> >       <OOI key="RASTERYDIM">1</OOI>
>> >    </OpenOptions>
>> >     DataType="UInt16"
>> >   </SimpleSource>
>> > Which is equivalent to:
>> > gdalinfo HDF4_SDS:UNKNOWN:"DATA_WITH_4D_DATASET.hdf":7 -oo RASTERXDIM=0
>> > -oo
>> > RASTERYDIM=0
>> > Even
>> > Spatialys - Geospatial professional services
>> > http://www.spatialys.com
>> > _______________________________________________
>> > gdal-dev mailing list
>> > gdal-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
