[gdal-dev] Problem reading WAFS GRIB2 file with gdal
Kurt Schwehr
schwehr at gmail.com
Mon Sep 19 06:16:54 PDT 2016
And just got this update from Arthur Taylor at NOAA.
-kurt
Please go here for release 2.07
http://www.weather.gov/mdl/degrib_download
http://www.nws.noaa.gov/mdl/degrib/ bounces you to the new site, but I see
that the old "Download page" (
http://www.nws.noaa.gov/mdl/degrib/download.php) doesn't.
When you get a chance, can you look it over and let us know if you have
specific issues? Mike Allard (CC'd) is working to pick up the ball on
items that have been dropped of late.
On Wed, Sep 14, 2016 at 9:10 AM, Kurt Schwehr <schwehr at gmail.com> wrote:
> FYI,
> degrib 2.05 from Dec 2015 is out here:
> http://slosh.nws.noaa.gov/degrib2/download.php
> -kurt
> On Wed, Sep 14, 2016 at 7:16 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Pierre,
>> > A bug seems to be already opened for this error :
>> > https://trac.osgeo.org/gdal/ticket/5768
>> I had a look and just added support for that kind of products in GDAL
>> trunk.
>> The issue was that Template 4.15 (
>> http://www.nco.ncep.noaa.gov/pmb/docs/grib2/grib2_temp4-15.shtml ) used
>> for
>> bands 4-37 wasn't supported before.
>> I've also refreshed the GRIB tables used to get parameter names from
>> latest
>> degrib v2.0.3
>> Now you get:
>> $ gdalinfo WAFS_blended_2016090700f06.grib2
>> Driver: GRIB/GRIdded Binary (.grb)
>> Files: WAFS_blended_2016090700f06.grib2
>> Size is 288, 145
>> Coordinate System is:
>> GEOGCS["Coordinate System imported from GRIB file",
>> DATUM["unknown",
>> SPHEROID["Sphere",6371229,0]],
>> PRIMEM["Greenwich",0],
>> UNIT["degree",0.0174532925199433]]
>> Origin = (-0.625000000000000,90.625000000000000)
>> Pixel Size = (1.250000000000000,-1.250000000000000)
>> Corner Coordinates:
>> Upper Left ( -0.6250000, 90.6250000) ( 0d37'30.00"W, 90d37'30.00"N)
>> Lower Left ( -0.6250000, -90.6250000) ( 0d37'30.00"W, 90d37'30.00"S)
>> Upper Right ( 359.375, 90.625) (359d22'30.00"E, 90d37'30.00"N)
>> Lower Right ( 359.375, -90.625) (359d22'30.00"E, 90d37'30.00"S)
>> Center ( 179.3750000, 0.0000000) (179d22'30.00"E, 0d 0' 0.01"N)
>> Band 1 Block=288x1 Type=Float64, ColorInterp=Undefined
>> Description = 0[-] RESERVED(11) (Reserved)
>> Metadata:
>> GRIB_COMMENT=ICAO Standard Atmosphere Reference Height [m]
>> GRIB_ELEMENT=ICAHT
>> GRIB_FORECAST_SECONDS=21600 sec
>> GRIB_PDS_PDTN=0
>> GRIB_PDS_TEMPLATE_NUMBERS=3 3 2 0 96 0 0 0 1 0 0 0 6 11 0 0 0 0 0 255
>> 0 0
>> 0 0 0
>> GRIB_REF_TIME= 1473206400 sec UTC
>> GRIB_SHORT_NAME=0-RESERVED(11)
>> GRIB_UNIT=[m]
>> GRIB_VALID_TIME= 1473228000 sec UTC
>> [...snip...]
>> Band 4 Block=288x1 Type=Float64, ColorInterp=Undefined
>> Description = 70000[Pa] ISBL="Isobaric surface"
>> Metadata:
>> GRIB_COMMENT=In-Cloud Turbulence [%]
>> GRIB_ELEMENT=CTP
>> GRIB_PDS_PDTN=15
>> GRIB_PDS_TEMPLATE_NUMBERS=19 21 2 0 96 0 0 0 1 0 0 0 6 100 0 0 1 17
>> 112
>> 255 0 0 0 0 0 0 3 1
>> GRIB_SHORT_NAME=70000-ISBL
>> GRIB_UNIT=[%]
>> [... snip ... ]
>> Band 37 Block=288x1 Type=Float64, ColorInterp=Undefined
>> Description = 30000[Pa] ISBL="Isobaric surface"
>> Metadata:
>> GRIB_COMMENT=Icing [%]
>> GRIB_ELEMENT=ICIP
>> GRIB_PDS_PDTN=15
>> GRIB_PDS_TEMPLATE_NUMBERS=19 20 2 0 96 0 0 0 1 0 0 0 6 100 0 0 0 117
>> 48
>> 255 0 0 0 0 0 2 3 1
>> GRIB_SHORT_NAME=30000-ISBL
>> GRIB_UNIT=[%]
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://schwehr.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160919/ba51f2d7/attachment.html>
