[gdal-dev] Writing descriptions to GeoTiff bands
Even Rouault
even.rouault at spatialys.com
Tue Sep 20 08:23:41 PDT 2016
Le mardi 20 septembre 2016 17:13:44, Andrew Bell a écrit :
> On Sun, Sep 18, 2016 at 5:49 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Le dimanche 18 septembre 2016 11:02:20, Sean Gillies a écrit :
> > > Hi Andrew, Even,
> > > I am so grateful you asked this question, Andrew.
> > UPDATE: Andrew, after digging, I believe you have hit
> > https://trac.osgeo.org/gdal/ticket/6592 whose fix hasn't yet reached any
> > released version.
> Thanks Even,
> It seems like doing something else to set the metadata change flag will
> make things work. Unfortunately, the change flag seems to be guarded so
> one has to make an actual change to get it to be set. Something like the
> following works, but is a little crufty and deserves a comment. Perhaps
> there's a better way?
> int nBands = 5;
> dataset->Create(filename, width, height, nBands, ...);
> for (int i = 1; i <= nBands; ++i)
> GDALRasterBand *band = dataset->GetRasterBand(i);
> band->SetDescription(someString);
> // Force metadata change flag so that description gets written.
> Current bug
> // (ticket 6592) requires something like this.
> band->SetOffset(band->GetOffset(NULL) + .00001);
> band->SetOffset(band->GetOffset(NULL) - .00001);
Or just
band->SetOffset(1)
band->SetOffset(0)
since 0 is the default offset (and if you don't customize it).
http://www.spatialys.com
