[gdal-dev] Multithread deadlock
Andrew Bell andrew.bell.ia at gmail.com
Mon Sep 26 07:06:26 PDT 2016
Deadlocks are usually easy to debug if you can get a traceback when
deadlocked.  If you can attach with gdb (or run in the debugger) and
reproduce and post the stack at the time ('where' from gdb), it should be
no problem to fix.  Trying to reproduce on different hardware can be
difficult.
On Mon, Sep 26, 2016 at 9:33 AM, Francisco Javier Calzado <
francisco.javier.calzado at ericsson.com> wrote:
> Hi guys,
> I am experiencing a deadlock with just 2 threads in a single reader &
> multiple writer scenario. This is, threads read from the same input file
> (using different handlers) and then write different output files. Deadlock
> comes when the block cache gets filled. The situation is the following:
> -          T1 and T2 read datasets D1 and D2, both pointing to the same
> input raster (GTiff).
> -          Block cache gets filled.
> -          T1 tries to lock one block in the cache to write data. But
> cache is full, so it tries to free dirty blocks from T2 (as seen in
> Internalize() method). For that purpose, it requires apparently a mutex
> from D2.
> -          However T2 is in a state where must wait for thread T1 to
> finish working with T2’s blocks. In this state, T2 has a mutex acquired
> from D2.
> At least, that is what it seems to be happening based on source code.
> Maybe I’m wrong, I don’t have a full picture overview about how GDAL is
> internally working. The thing is that I can reproduce this issue with the
> following test code and dataset:
> https://drive.google.com/file/d/0B-OCl1FjBi0YSkU3RUozZjc5SnM/
> view?usp=sharing
> Oddly enough, ticket with number #6163 is supposed to fix this, but its
> failing in my case. I am working with GDAL 2.1.0 version under VS2015 (x32,
> Debug) compilation.
> Even, what do you think?
> Thanks!
> Javier C.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160926/9ae50455/attachment.html>
