[gdal-dev] GML lat-lon coverages and interoperability
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Mon Apr 3 06:19:18 PDT 2017
Great, first hit from Andrea. I am awaiting if Even strikes back. His creation (GDAL JP2OpenJPEG driver) writes out EPSG:4326 coverage into GML JP2 this way, without having gridFunction.
<gml:FeatureCollection
   xmlns:gml="http://www.opengis.net/gml"
   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
   xsi:schemaLocation="http://www.opengis.net/gml http://schemas.opengis.net/gml/3.1.1/profiles/gmlJP2Profile/1.0.0/gmlJP2Profile.xsd">
  <gml:boundedBy>
    <gml:Envelope srsName="urn:ogc:def:crs:EPSG::4326">
      <gml:lowerCorner>61.7282236395245 24.7248340978191</gml:lowerCorner>
      <gml:upperCorner>61.7838827490233 24.8422668729657</gml:upperCorner>
    </gml:Envelope>
  </gml:boundedBy>
  <gml:featureMember>
    <gml:FeatureCollection>
      <gml:featureMember>
        <gml:RectifiedGridCoverage dimension="2" gml:id="RGC0001">
          <gml:rectifiedGridDomain>
            <gml:RectifiedGrid dimension="2">
              <gml:limits>
                <gml:GridEnvelope>
                  <gml:low>0 0</gml:low>
                  <gml:high>15517 7354</gml:high>
                </gml:GridEnvelope>
              </gml:limits>
              <gml:axisName>x</gml:axisName>
              <gml:axisName>y</gml:axisName>
              <gml:origin>
                <gml:Point gml:id="P0001" srsName="urn:ogc:def:crs:EPSG::4326">
                  <gml:pos>61.7838789652633 24.7248378815791</gml:pos>
                </gml:Point>
              </gml:origin>
              <gml:offsetVector srsName="urn:ogc:def:crs:EPSG::4326">0 7.56751998624388e-006</gml:offsetVector>
              <gml:offsetVector srsName="urn:ogc:def:crs:EPSG::4326">-7.56751998624388e-006 0</gml:offsetVector>
            </gml:RectifiedGrid>
          </gml:rectifiedGridDomain>
          <gml:rangeSet>
            <gml:File>
              <gml:rangeParameters/>
              <gml:fileName>gmljp2://codestream/0</gml:fileName>
              <gml:fileStructure>Record Interleaved</gml:fileStructure>
            </gml:File>
          </gml:rangeSet>
        </gml:RectifiedGridCoverage>
      </gml:featureMember>
    </gml:FeatureCollection>
-Jukka-
Lähettäjä: andrea.aime at gmail.com [mailto:andrea.aime at gmail.com] Puolesta Andrea Aime
Lähetetty: 3. huhtikuuta 2017 15:58
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Kopio: 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org) <gdal-dev at lists.osgeo.org>; geoserver-devel at lists.sourceforge.net
Aihe: Re: [gdal-dev] GML lat-lon coverages and interoperability
On Mon, Apr 3, 2017 at 2:32 PM, Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
With orthophoto coverages I believe that all cases could be handled with the default gridFunctions: startPoint at gml:Low, axisOrder +1 +2, sequence rule “Linear”. As far as I have understood GDAL trusts that this is also what the other partners do. However, it seems that GeoServer developers have decided to handle the latitude-longitude axis flip in WCS 2.0.1 by changing the order of grid axis with a function instead of writing the offsetVectors to suit with the default +1 +2 axis order.
<gml:coverageFunction>
<gml:GridFunction>
<gml:sequenceRule axisOrder="+2 +1">Linear</gml:sequenceRule>
<gml:startPoint>0 0</gml:startPoint>
</gml:GridFunction>
</gml:coverageFunction>
Hi Jukka,
the decision was not arbitrary, and imho, necessary.
Rasters pixels are normally represented as east/north, but OGC forces us to describe geographic data in lat/lon order.
So how do you tell the client, "look, I'm telling you that the axis order is north/east, but really, I'm giving you back data in east/north order instead"?
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170403/a5dcb4ee/attachment-0001.html>
