[gdal-dev] Is it possible to add new fields to a shapefile and populate then?
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Mon Apr 3 21:37:04 PDT 2017
Stephen Woodbridge wrote
> Hi All,
> I have a shapefile(s) and I want to read the features, generate some
> metrics about each feature and then add them to the that feature. I'm
> using python and one obvious way to to in effect create a new shapefile
> with the columns I need to add, then copy the existing shapefile to the
> new one adding the additional metrics.
> I wondering if I can add the new columns to the shapefile, then do a
> read and update.
> Pros and cons to these approaches? and how to do the later one if
> possible?
> I looked at the python gdal/ogr cookbook and didn't this specific
> example. But I thinking of something along the lines of:
> 1. open the dataset for read/write
> 2. layer.CreateField() to add the new fields
> 3. loop through the features in the layer
> 4. and use feature.SetField()
> 5. and feature = None to commit the changes
> will this work?
> Thanks,
> -Steve
You can demonstrate that it is possible with ogrinfo:
ogrinfo -sql "alter table test add column foo integer" test.shp
ogrinfo -dialect sqlite -sql "update test set foo=2" test.shp
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Is-it-possible-to-add-new-fields-to-a-shapefile-and-populate-then-tp5315568p5315579.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
