[gdal-dev] Is it possible to add new fields to a shapefile and populate then?
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Apr 4 07:19:00 PDT 2017
Rutger,
Thanks, that did the trick.
-Steve
On 4/4/2017 6:15 AM, Rutger wrote:
> Stephen Woodbridge wrote
>> Hi Jukka,
>> Ahh, good point, I always seem to forget that fact.
>> I have gotten the python code to add the new fields, but the data is not
>> getting written to the file.
>> # open the shapefile
>> driver = ogr.GetDriverByName('ESRI Shapefile')
>> dataSource = driver.Open(infile, 1) # open for rw
>> if dataSource is None:
>> print "ERROR: could not open '%s' as shapefile!" % (infile)
>> sys.exit(1)
>> layer = dataSource.GetLayer()
>> layer.CreateField(ogr.FieldDefn("area", ogr.OFTReal))
>> for feature in layer:
>> geom = feature.GetGeometryRef()
>> feature.SetField("area", geom.GetArea())
>> feature = None
>> dataSource = None
>> In the cookbook example for "Create a New Shapefile and Add Data" there
>> is a call to:
>> layer.CreateFeature(feature)
>> but I do not see an equivalent call for:
>> layer.UpdateFeature(feature)
>> So How do I update the feature and force the data to get written to the
>> shapefile. I'm presuming the CreateFeature will append a new record
>> which is not what I want.
>> -Steve
>> This email has been checked for viruses by Avast antivirus software.
>> https://www.avast.com/antivirus
>> gdal-dev mailing list
>> gdal-dev at .osgeo
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Hey Stephen,
> I think you looking for "layer.SetFeature(feature)", which you can add right
> before destroying the changed feature object withing your loop.
> Regards,
> Rutger
> View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Is-it-possible-to-add-new-fields-to-a-shapefile-and-populate-then-tp5315568p5315653.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev at lists.osgeo.org
