[gdal-dev] configure: error: HDF4 support requested with arg "/usr/lib/hdf4", but neither hdf4 nor mfhdf lib found
Charles Dosantos
devquestions2 at gmail.com
Thu Apr 6 04:06:39 PDT 2017
Hello,
I am trying to build gdal 2.1.3 on centos , but running into this error.
Many people have reported similar errors.
Is there any solution for it ?
hdf4 drivers build were configured using and the build seemed okay.
./configure --with-jpeg=/usr/lib/jpeglib --disable-netcdf --disable-fortran
--prefix=/usr/lib/hdf4
gdal configure command I used
: ./configure --with-hdf4=/mnt/nfs/share1/software/hdf4 --disable-netcdf
--disable-fortran
Folder /usr/lib/hdf4/lib contains the libraries.
ls on /usr/lib/hdf4/lib returns
libdf.a libdf.la libhdf4.settings libmfhdf.a libmfhdf.la
Thanks !
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170406/e3e46dff/attachment.html>
