[gdal-dev] SQLite-SQL problem with some layer names
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Wed Apr 12 07:45:57 PDT 2017
I had a try with editing the .dox file that is used for generating http://www.gdal.org/ogr_sql_sqlite.html<http://www.gdal.org/ogr_sql_sqlite.html> with changeset #37971. Could you check if the text makes sense and appears right?
-Jukka-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170412/a970eb9f/attachment.html>
