[gdal-dev] GDAL 2.2.0 beta 1 available
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Apr 18 09:56:13 PDT 2017
On 2017-04-18 1:50 PM, Jeff McKenna wrote:
> On 2017-04-14 5:10 AM, Even Rouault wrote:
>> I have prepared the GDAL/OGR 2.2.0 Beta 1 release. It will potentially
>> be followed by a second beta, or directly by a RC1 if things go well.
>> The source is available at:
> Tested in the MS4W build environment on Windows, with VS 2015 and 2012.
> No issues compiling or running with VS 2015. With VS 2012 I get this
> error right away when starting to compile (cpl_vsil_curl.cpp) :
> https://pastebin.com/hBi6sv0c
> -jeff
I just noticed a very recent change (after beta1) to GDAL of "fix
compilation with VS2015" <--- this is confusing, as I just tested
successfully VS2015 for the full MS4W build (includes netcdf-c-4.4.0,
libkml, poppler, etc etc). Maybe your recent change was not needed in
my build environment? odd.
-jeff
