[gdal-dev] GDAL 2.2.0 beta 1 available
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Apr 18 10:56:38 PDT 2017
On 2017-04-18 2:06 PM, Jeff McKenna wrote:
> On 2017-04-18 1:56 PM, Jeff McKenna wrote:
>> On 2017-04-18 1:50 PM, Jeff McKenna wrote:
>>> On 2017-04-14 5:10 AM, Even Rouault wrote:
>>>> I have prepared the GDAL/OGR 2.2.0 Beta 1 release. It will potentially
>>>> be followed by a second beta, or directly by a RC1 if things go well.
>>>> The source is available at:
>>> Tested in the MS4W build environment on Windows, with VS 2015 and 2012.
>>> No issues compiling or running with VS 2015. With VS 2012 I get this
>>> error right away when starting to compile (cpl_vsil_curl.cpp) :
>>> https://pastebin.com/hBi6sv0c
>>> -jeff
>> I just noticed a very recent change (after beta1) to GDAL of "fix
>> compilation with VS2015" <--- this is confusing, as I just tested
>> successfully VS2015 for the full MS4W build (includes netcdf-c-4.4.0,
>> libkml, poppler, etc etc). Maybe your recent change was not needed in
>> my build environment? odd.
>> -jeff
> Also note that I recently (January?) worked with the netcdf-c devs
> regarding compiling issues with VisualStudio with their 4.4.1 release:
> https://github.com/Unidata/netcdf-c/issues/304
> anyway, that's now too much feedback from me here, ha! :)
> -jeff
my 2012 issue was a missing -DNOMINMAX in my nmake.opt Now both 2012 and
2015 work fine. great work Even!
-jeff
