[gdal-dev] GDAL 2.2.0 beta 2 available
Even Rouault even.rouault at spatialys.com
Wed Apr 26 04:05:31 PDT 2017
Sean,
> I'd love to be able to build 2.2.0 on this slightly out of date compiler,
> but if 2.2.0 will require C++11, I'll get with the program.
2.2.0 doesn't rquire C++11
It seems that this compiler undefines the C99 isnan() macro in all cases as soon as <cmath> is
included.
Can you revert all the changes of your tree and apply the attached patch ?
--without-cpp11 will probably still be needed.
If that doesn't work, can you send the output of the following:
gcc -dM -E - < /dev/null
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170426/44429a52/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170426/44429a52/attachment.bin>
