[gdal-dev] Need solution for C# setup, with error at OSGeo.OGR registration
C. Zeng chqzeng at gmail.com
Wed Aug 9 18:04:36 PDT 2017
Thank you Eric and Tamas,
I have switched to python with Gdal, due to this setup issue with C# and
other platform consideration. Thank you two for the help!.
Best,
Chui,
On Tue, Aug 8, 2017 at 4:18 PM, Eric Wenger ARA/SED <ewenger at ara.com> wrote:
> *Chui,*
> *An example here is that you need to have proj.dll in the path so that
> gdal.dll will load from the PInvoke.  You can use dependency walker to find
> other dependencies.*
> *From:* gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Tamas
> Szekeres
> *Sent:* Tuesday, August 01, 2017 12:15 PM
> *To:* C. Zeng
> *Cc:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] Need solution for C# setup, with error at
> Hi,
> You probably have multiple dll dependencies availabe in the path. Try
> copying all the dependencies from the same package to the location where
> your excutable is running.
> Best regards,
> Tamas
> Az iPhone-omról küldve
> 2017. aug. 1. dátummal, 17:08 időpontban C. Zeng <chqzeng at gmail.com> írta:
> ​Hello all,
> I am trying to setup the GDAL in C#.NET 2015, with an error at the
> registration of the Ogr. A previous post
> <http://osgeo-org.1560.x6.nabble.com/gdal-dev-Need-solution-for-C-exception-OSGeo-OGR-OgrPINVOKE-td5062693.html#a5329043>
> stated the exact same problem but without a solution, I tried to reply in
> that post but failed,thus send this email instead.
> That previous post described my problem very well:
> "I am using *ogr_csharp.dl*l in my c# program. See the following code
> snippet:
> using OSGeo.OGR;
> namespace Test
>     public class Test
>         public Test()
>                   Ogr.RegisterAll();
> Then the following exception message was thrown out when the program is
> executed:
> *{"The type initializer for 'OSGeo.OGR.OgrPINVOKE' threw an exception."}
> *System.Exception {System.TypeInitializationException}*
> Does anyone know how to resolve this issue? "
> Some more details for my case. My steps are:
> - downloaded the stable or daily stable release (same error later) from
> here
> <http://www.gisinternals.com/query.html?content=filelist&file=release-1800-x64-gdal-2-1-mapserver-7-0.zip>
> - added the "...\bin" and "...\bin\gdal\csharp" to Environment Variable,
> setup a sample project,
> - add the 4 "###sharp.dll" from csharp folder to project reference.
> - import namespace:  using OSGeo.OGR; using OSGeo.OSR;  and add a simple
> line "Ogr.RegisterAll(); "
> Then I can successfully build the project, but with the following error
> msg. I tried all possible solutions by Google plus this forum such as this
> <http://osgeo-org.1560.x6.nabble.com/gdal-dev-GDAL-OGR-64bit-PINVOKE-Exception-td3745305.html>
>  and this
> <http://osgeo-org.1560.x6.nabble.com/c-Bindings-in-Mono-Linux-td3758565.html#a3758569>
> test all the x64/x86 , debug/release, switches, no luck.
> Any comment is appreciated, thank you!
> Chui
> --------------------------error message --------------------------
> *Unhandled Exception: System.TypeInitializationException: The type
> initializer fo  r 'OSGeo.OGR.OgrPINVOKE' threw an exception. --->
> System.TypeInitializationExcep  tion: The type initializer for
> 'SWIGExceptionHelper' threw an exception. ---> Sy
> stem.BadImageFormatException: An attempt was made to load a program with an
> inco  rrect format. (Exception from HRESULT: 0x8007000B)     at
> OSGeo.OGR.OgrPINVOKE.SWIGExceptionHelper.SWIGRegisterExceptionCallbacks_Og
> r(ExceptionDelegate applicationDelegate, ExceptionDelegate
> arithmeticDelegate, E  xceptionDelegate divideByZeroDelegate,
> ExceptionDelegate indexOutOfRangeDelegate  , ExceptionDelegate
> invalidCastDelegate, ExceptionDelegate invalidOperationDeleg  ate,
> ExceptionDelegate ioDelegate, ExceptionDelegate nullReferenceDelegate,
> Exce  ptionDelegate outOfMemoryDelegate, ExceptionDelegate
> overflowDelegate, Exception  Delegate systemExceptionDelegate)     at
> OSGeo.OGR.OgrPINVOKE.SWIGExceptionHelper..cctor()     --- End of inner
> exception stack trace ---     at
> OSGeo.OGR.OgrPINVOKE.SWIGExceptionHelper..ctor()     at
> OSGeo.OGR.OgrPINVOKE..cctor()     --- End of inner exception stack trace
> ---     at OSGeo.OGR.OgrPINVOKE.RegisterAll()     at
> OSGeo.OGR.Ogr.RegisterAll()     at TestProj.Main(String[] args) in
> \user\Downloads\Workspace\TestProj\project.cs:line 47*
> and also the following log info:
> *'TestProj.vshost.exe' (CLR v4.0.30319: TestProj.vshost.exe): Loaded
> 'C:\WINDOWS\Microsoft.Net
> <http://Microsoft.Net>\assembly\GAC_64\mscorlib\v4.0_4.0.0.0__b77a5c561934e089\mscorlib.dll'.
> Cannot find or open the PDB file.  'TestProj.vshost.exe' (CLR v4.0.30319:
> 'C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualStudio.HostingProcess.Utilities\14.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualStudio.HostingProcess.Utilities.dll'.
> TestProj.vshost.exe): Loaded 'C:\WINDOWS\Microsoft.Net
> <http://Microsoft.Net>\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll'.
> <http://Microsoft.Net>\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll'.
> <http://Microsoft.Net>\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll'.
> 'C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualStudio.HostingProcess.Utilities.Sync\14.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll'.
> 'C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualStudio.Debugger.Runtime\14.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualStudio.Debugger.Runtime.dll'.
> '\user\Downloads\Gdal_folder\TestProj\bin\Debug\TestProj.vshost.exe'.
> <http://Microsoft.Net>\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll'.
> <http://Microsoft.Net>\assembly\GAC_MSIL\System.Xml.Linq\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.Linq.dll'.
> <http://Microsoft.Net>\assembly\GAC_MSIL\System.Data.DataSetExtensions\v4.0_4.0.0.0__b77a5c561934e089\System.Data.DataSetExtensions.dll'.
> <http://Microsoft.Net>\assembly\GAC_MSIL\Microsoft.CSharp\v4.0_4.0.0.0__b03f5f7f11d50a3a\Microsoft.CSharp.dll'.
> <http://Microsoft.Net>\assembly\GAC_64\System.Data\v4.0_4.0.0.0__b77a5c561934e089\System.Data.dll'.
> <http://Microsoft.Net>\assembly\GAC_MSIL\System.Net.Http\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Net.Http.dll'.
> <http://Microsoft.Net>\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll'.
> Cannot find or open the PDB file.  The thread 0x2228 has exited with code 0
> (0x0).  The thread 0x1b30 has exited with code 0 (0x0).  The thread 0x2a64
> has exited with code 0 (0x0).  'TestProj.vshost.exe' (CLR v4.0.30319:
> '\user\Downloads\Gdal_folder\TestProj\bin\Debug\TestProj.exe'. Symbols
> loaded.  The thread 0x2c20 has exited with code 0 (0x0).
> '\user\Downloads\Gdal_folder\TestProj\bin\Debug\ogr_csharp.dll'. Module was
> built without symbols.  Exception thrown: 'System.DllNotFoundException' in
> ogr_csharp.dll  Exception thrown: 'System.TypeInitializationException' in
> ogr_csharp.dll  An unhandled exception of type
> 'System.TypeInitializationException' occurred in ogr_csharp.dll  Additional
> information: The type initializer for 'OSGeo.OGR.OgrPINVOKE' threw an
> exception.  The program '[2244] TestProj.vshost.exe' has exited with code 0
> (0x0)*
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170809/b5243b2a/attachment-0001.html>
