[gdal-dev] PDF not oriented as expected
Gane R
gane.prog at gmail.com
Mon Aug 14 03:06:16 PDT 2017
I had a chance to work with prebuild gdal-2-1-3 bin, I tried to convert a
PDF to TIFF, with attached PDF, the PDF is not oriented to the north
rotation as expected on the TIFF.
I tried to work with source and found the angle dfRotation is reported as
zero. The resultant GeoTIFF output is not north oriented. Here is a link to
PDF
https://drive.google.com/file/d/0B4shTM1bPS5TX1F2Wk8wTWk5MnM/view?usp=sharing
Gane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170814/b3ee1d6f/attachment.html>
