[gdal-dev] Kakadu 7.10 (7_A)
Bugbuster philippe.ghesquiere at airbus.com
Mon Aug 21 04:50:29 PDT 2017
Dear Even,
thanks for your valuable hints.
I do agree that the creation/deletion errors of the poInput object should
not be part of GDAL source code. This is the reason why I did not open a
GDAL ticket, but asked David Taubman for help.
I may try to rebuild the whole application in debug mode with /MDd flag to
make sure everything is consistent for the compiler.
And again thanks for the link to "Dr. Memory" : I will ask for consultations
Sincerly
Philippe
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Kakadu-7-10-7-A-tp5331632p5331989.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
