[gdal-dev] How to set layer name in SQL query?
Denis Rykov rykovd at gmail.com
Wed Aug 23 09:24:34 PDT 2017
When I perform the following command:
$ ogrinfo -dialect SQLITE -sql "SELECT COUNT(*) summary FROM
Export_Output_4" Export_Output_4.shp
I get result:
INFO: Open of `Export_Output_4.shp'
      using driver `ESRI Shapefile' successful.
Layer name: SELECT
Geometry: None
Feature Count: 1
Layer SRS WKT:
(unknown)
summary: Integer (0.0)
OGRFeature(SELECT):0
  summary (Integer) = 703
Is it possible to change layer name in output ("SELECT" now).
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170823/feec8a52/attachment.html>
